2025 XP 5 tail lights go out 1 minute after turning ignition on.
Norton
jetpwrd69
2025 XP 5. After ignition is turned on the tail lights come on for about a minute and then go off & dont come back on. Ive checked fuses, switched relays around as they are all the same number. Any idea's what could be wrong?
If you have a turn signal kit installed, I’d check the rear harness plug. I’ve had a couple of them push the pins out when they’re plugged back together.
If no turn signal kit, I’d start at the taillights with an electrical tester and check for power at the taillight plug. Then down at the harness plug on the frame.
