Scottvoyles
Has anyone had any experience with mounting 5150 12-in fat whip lights to a 2024 expedition ADV5? Looking for the mounting etc and wiring advice
Mine were $109 for both (2) including remote. The brackets have not arrived yet, they areI looked on Amazon and found two different lights one was $109 and the other was $56 both with the same description as you had in your post any idea what the difference is? I'd look and couldn't find anything. Also trying to figure out what mounting bracket works on the expedition AdV 5
Not sure waiting to get them and try them out, but my hope is that they will fit since they fit the PRO cage which I believe is the same support bars, not completely round. If they don't I will post but I think they well. The Youtube video on an xPedition with the same lights seem to have them.Just checking because I don't have my unit with me it's at the shop getting some things added. Are you sure that the brackets that you mentioned will fit on the ADV5 next to the back window? Before I order just wanted to make sure. Thank you very much
I bought those whips dream motor 12-in, I found brackets for an ADV5 but I found that the base of the whip will not allow the window to open on the back. I did some MacGyvering and ground off a flat spot but wasn't thinking that the actual whip was the same size and there isn't enough room to grind off the same amount to allow the window to close. Any ideas?Thank you sir I will take a look at that on Amazon. What brackets did you order and did you put two or one?
The main issue is not being able to open the back window I think I understand the wiring to the tail lights. Thank you very muchSorry don't have an ADV5 so can't help with the window issue. However, on the wiring you might consider running the lites off a pig tail plugged into the rear tail lites. Worked for me, since they have a remote controller to manage the lights.
www.vengeancepowersports.com
Do you possibly have the link for the pig tail Im thinking of doing the same with Gorilla Whips TIA !!Doing it now. Waiting on the brackets to complete. Wired and ready to go. I used tail light pig tail for power since the ones I bought only need power as they included a remote for all; on/off, color schemes etc. I didn't want to go thru all the work of wiring it thru the rear and the dash etc. I prefer not taking all the front end/dash stuff apart.
DREAMOTOR Whip Lights, 2Pcs 1FT Fat Spiral RGB LED Whip Lights for Side by Side with Wireless Remote and APP Control, bought all on Amazon.
