EricB1
On my last trail ride in the desert here is AZ I noticed that the engine temp was running in the 202 to 205 degrees. I seem to remember engine temp to usually run between 178 to 188 under the same conditions. The outside temp was 77 degrees and basically a flat non technical trail. What struck me as odd was when I turned on the AC the temp immediately dropped back to the 180 degree range and stayed there while the AC was on. Is this temp swing normal when riding and then decreasing when the AC is turned on?
