Oem plow with hydraulic angle ram
Theo
Superduty1!
Has anyone had to add fluid to their hydraulic angle ram and if so is there a good method to bleeding the air out of the cyclinder. Had an issue where my plow was stuck at full left and was trying to let the pressure off so we could at least turn it back straight and in the process of elimination we opened the set screw on the side and was able to straighten it by hand and added what fluid we could and put the screw back in, After that the plow wouldnt turn right or left and we finally found a blown fuse. Now everything works but when turning to the right its very slow so I am assuming I have air in the system. Anyone have any thougths or ideas?
