32 Razor Pro Tires on Expedition XP Northstar(2)
Tippy Express
Indiana
Dealer just swapped out my brand new stock tires for brand new razor pro 32’s. Not horrible $$$$. Incredible ride quality difference. Lowered RPM`s a bit. Minor mod made a really nice difference! I have the best Dealer in INDIANA if anyone needs a referral…
What tires are you talking about? Those from a Turbo R? If so they are soft and won't last long
those came on my Turbo R. They have soft sidewalls, damage easy and don't last long
Thank you for info. Yes. It was a low cost way to see if that made a difference in RPM and ride quality. If I keep the machine next year I will buy 32’s with Bead-locks and research the tire. It made a huge difference all around. Thank you
It looks beefy with those tires! Thanks for sharing these photos and info.
Tippy Express. looks like both the front and the rears are 32 x 10 x 15's. Your rig looks boss with this setup
Was at my dealer the other day and was so close to doing the same thing. Ended up the set they had wouldn't fit. They do look good Tippy.
I'm running 32X10R14 Maxxis Carnivores on my Xpedition and don't have any rubbing problems. I put 1" spaces on the Xpedition to go from the 5x4.5 bolt pattern to the 4x156 bolt pattern of the 14" wheels the tires were on. It rides smoother and extra ground clearance is nice.
