I'm on a mission to connect Ride Command to Starlink Mini
JohnnyG
Fort Myers, FL
I’m not sure what Polaris was thinking when they decided to require Ride Command to use Bluetooth tethering instead of a good old-fashioned Wi-Fi connection. They really missed the mark on this one.
Here’s my problem: Samsung phones will not allow you to Bluetooth tether a Wi-Fi connection. The phone forces Wi-Fi off. I can Bluetooth tether the mobile connection, but that does not help much because I usually do not have cell service where I ride.
I run a Starlink Mini on the roof of my XP5, so I almost always have a solid connection.
The plan is to add a Raspberry Pi 4 to act as a bridge between Ride Command, using Bluetooth, and the Starlink Wi-Fi connection.
I have the hardware and took a run at it last night. Right now, I am having trouble getting the Pi to connect to Ride Command, but I will keep working on it.
Stay tuned.
JG
They missed the mark on a lot of things on the ride command.
Front and rear cameras should allow recording if a flash drive is plugged in.
It should allow route planning on device, rather than building a route off device then uploading.
It should allow hardwired music playback through the usb connection, rather than only through Bluetooth. (CarPlay/Android Auto would be nice) They might have to finally up their game on this with all the other manufacturers 1-upping them now.
And yes, definitely Starlink integration would be a major benefit.
I plug an iPhone, in use as an iPod to play music on Ride Command. Works very well.
I have my Samsung 8 Tablet in use with a Kemimoto stand.
This is it:
I use my Tablet with Avenza Maps, and use the Ride Command screen for other things.
I wouldn't mind having a Starlink set up for the Xpedition. But I already have
a Starlink account for the house, a Starlink account for the RV, not sure I can afford three??
This is it:
I bought the Starlink mini for $299 from Home Depot. I have it on the standby plan. It's fast enough to play music and load maps. Standby was $5 month but just went up to $10 month.
You also can't drive over 10 mph in standby mode or it shuts off.
My thread on how I mounted it is here Starlink mini packout mount
I already have a Starlink account for the house, a Starlink account for the RV, not sure I can afford three??
If your RV account is roaming, you can put that starlink in the Xpedition. If it is a standard, you would need a big power bank to power it. But, it would work.
JG
This is it:
I have the same setup, except I use OnX on my tablet.
This is it:
Pirate,
Are you able to access the windshield handle on tip out glass while using Kemimoto tablet holder?
