I would like to install a more robust AGM battery in place of the small stock flooded lead acid battery. It appears as though a type 86 automotive battery will fit just fine. In fact, Polaris has a bolt in bracket installed on the mounting tray to skinny it up to the stock battery size. If you remove the plate, it seems as though it was made for a larger battery such as a type 86 size. The only issue I see is that most automotive batteries I have checked into have the positive post on the left, which is opposite of the Polaris small stock battery. Has anyone installed a large automotive battery as a replacement? If so, what did you use and what modifications did you have to make? No, I do not want to install a dual battery system...just sayin'.
