I also think a lot of the noise comes from the valve train.
Oh, it does! It comes from the entire drivetrain.
The Prostar II engine is a high performance high RPM engine. It was designed and developed for the RZR XP. The idea with putting it in the Xpedition was to have a SxS with a somewhat utility build, but a performance powertrain, that would bridge the gap between utility and sport.
There isn’t a high performance SxS out there that’s quiet. The problem becomes exacerbated by having a completely enclosed cabin. My ‘24 XP5 Ultimate, with the open cab, was quieter at the driver location than from the same position in a Northstar. Even using the Canvas uppers on the doors didn’t make it noticeably worse, because it’s a soft material that can absorb sound rather than reflecting it.
My point is that Polaris is still going at the noise problem by neutering performance, rather than sound dampening, and closing off all the openings into the cabin.
Their claim is 9db sound reduction. But my guess is that’s only in comfort mode, where there’s essentially no performance. It does appear they’ve re-designed their clutch weights and profiles, with the claim of 1 second faster 0-50. (Again assuming that’s in sport mode where the Numatix is disengaged) the new clutch weights are 75g. That’s between the original, early ‘24 at 66g and the comfort weights at 81g. There is a difference in shift profiles, with both the original and comfort being a 44 and the new ones a 47.
So here’s what we’ve been doing since late 2023… By doing Aftermarket Assassins or Gilomen clutch kits and ECU tunes (tuning for performance), we’ve been doing much better than 1 second faster 0-50. As much as 4 seconds, when I was paying attention to that.
Then, with the machine running 500-700 rpms higher than the OEM tune and clutch, we’ve achieved a 7-9db noise reduction with sound dampening and insulation… In sport mode… at peak performance for the engine.
I am impressed with the idea and tech of the Numatix system. But using it as the means of noise reduction just feels like Comfort Clutch 2.0 And it only works by removing the “Sport” from the SxS.
